Traffic Bot project was created to emulate traffic from various different locations and automate the visitor hits on a website. While this is an automated bot, the way it actually works is that, it opens a browser, uses the provided URL and stays for the specified duration. In other words, it is just as a human would open a website on a browser or a new tab.
The engine provided, sits on a Linux system and keeps repeating the above activity till the specified count is met. The process of setting up the system may require minimum level of technical knowhow. However, the purpose of this document is to make sure that the entire process is as easy as possible. If your virtual Linux server is ready the entire process should not take more than 10 minutes.
Nôm na là phần mềm này cài lên 1 vps linux để chạy. Khi chạy, nó sẽ tạo ra các traffic từ nhiều locations khác nhau truy cập vào website đích. Điều này sẽ giúp web bạn có được traffic cao. Tuy nhiên, cá nhân mình khuyến khích đừng lạm dùng, vì nếu bạn sử dụng quá nhiều kéo theo traffic quá cao sẽ bị google giảm hạng website nhé.
Link tải Traffic Bot Engine:
https://www.uploadadz.com/ji1xklp4lzbj
https://usersdrive.com/dwayn9nrsz66.html
https://dailyuploads.net/viircvkgbv5t
https://dir50.cc/t2wbwmdd21pg
http://fileflares.com/afvtxo6tgypt/Share-Projects.Com-traffic-bot-engine.rar.html
http://www.4file.net/14cvlcfuxl8z/Share-Projects.Com-traffic-bot-engine.rar.html
