Our Speed Checker app easily, quickly and accurately measures your Wi-Fi network AND Mobile Internet Speed (download, upload and ping) up to 1 Gb/s.
Your Wi-Fi connection could be slowing you down. Use our built-in Wi-Fi Speed Test to identify problems with your Wi-Fi Speed and help you improve it. This could be as simple as moving your device a few feet! Our test compares your actual speed with the maximum attainable from your Wi-Fi router.
Background location is required for the Wi-Fi health monitoring feature which runs periodic Wi-Fi network scans when the app is not in use. This helps identify problems with your home wifi that are slowing you down.
It is specifically created for mobile devices to ensure accurate and reliable results. Great for gamers and VoIP users to test connections: Users can choose to test the speed to servers located Worldwide, Including the UK, USA, EU, Far East and South America.
Your results history shows Wi-Fi and mobile/LTE results. Identify the fastest providers in your area using our dynamic results map to compare results.
Features:
• New: Full test feature allows additional streaming and web tests
• New: Drive Test feature allows continual testing with control of frequency and data
• Modern and intuitive design
• Rate Your Provider
• Wi-Fi connection speed test (link speed AND throughput)
• Identify congested, slow and unstable Wi-Fi
• Dynamic results map to compare your speeds with others
• 5G, 4G, 3G, LTE, Wi-Fi, GPRS
• Accurate up to 1 Gb/s
• Worldwide servers
• Full history
• Easy sharing of results
6.0 and up
Home Page:
SpeedChecker Speed Test - Apps on Google Play
Easy and accurate mobile and Wi-Fi SpeedTest up to 1 Gb/s. UK, USA and Worldwide
![TIgOAI7.gif](https://i.imgur.com/TIgOAI7.gif)
