![1681163896_ip-tools-wifi-analyzer.png](https://diakov.net/uploads/posts/2023-04/1681163896_ip-tools-wifi-analyzer.png)
IP Tools: WiFi Analyzer is a powerful tools for boost, speed up and setup networks. Helps to quickly detecting any computer wifi problems, ip address and boosting wifi and mobile connection performance. This is a must-have app for all home WiFi users, IT experts and network router administrators.
The app combines the most popular utilities usually found on your desktop PC. Tools will help you fix a problem with signal strength, wifi router or optimize the connection in home network when you are hundreds of miles away. You also can turn on or reboot devices in home or corporate network with Wake on LAN feature.
IP Tools has a simple interface, so you can receive within seconds full information about your network, find out local, internal or external wifi address (with my ip), SSID, BSSID, dns, ping time, wifi speed, signal, broadcast address, gateway, mask, country, region, city, isp provider’s geographical coordinates (latitude and longitude), whois, netstat and other basic information.
The IP Tools app provides access to the most popular wifi utilities that administrators and users often use on their computers.
Features:
• Ping
• WiFi & LAN Scanner
• Port Scanner
• DNS Lookup
• Whois - Provides information about a website and its owner
• Router Setup Page and router admin tool
• Traceroute
• WiFi Analyzer
• Find address with "my ip" feature
• Connection Log
• IP Calculator
• IP & Host Converter
• Network statistics (netstat)
• And so much more...
WiFi analyzer will help you get full and clear picture of your network state, check wifi speed. With IP Tools, analysis and optimization are fast, easy and friendly. The app’s benefits go far beyond the above list. Download app and boost your network today!
Importnant: Permissions
ACCESS_COARSE_LOCATION & ACCESS_FINE_LOCATION
NEEDS для WiFi network Analyzer and SSID detection.
It's Android OS requirement.
What New:
IP Tools 8.69
● Hotfix
5.0 and up
Home Page :
IP Tools: WiFi Analyzer - Apps on Google Play
Ultimate WiFi Scanner & Network Utilities. Ping, DNS, ISP, IP tracker
![P6eRbc.png](https://lookimg.com/images/2020/12/08/P6eRbc.png)
