Mod Info:
- Premium / Paid features unlocked;
- Disabled / Removed unwanted Permissions + Receivers + Providers + Services;
- Optimized and zipaligned graphics and cleaned resources for fast load;
- Ads Permissions / Services / Providers removed from Android.manifest;
- Ads links removed and invokes methods nullified;
- Ads layouts visibility disabled;
- Google Drive Cloud works;
- Google Play Store install package check disabled;
- Debug code removed;
- Remove default .source tags name of the corresponding java files;
- Analytics / Crashlytics / Firebase disabled;
- Facebook ads bundled SDK removed completely;
- Promo Apps removed from menu;
- No startup with promo page;
- No active trackers or advertisements;
- Languages: Full Multi Languages;
- CPUs: armeabi-v7a, arm64-v8a;
- Screen DPIs: 120dpi, 160dpi, 240dpi, 320dpi, 480dpi, 640dpi;
- Original package signature changed;
- Release by Balatan.
AVG Cleaner is cleaning tool that has let nearly 50 million people worldwide clean their devices.
AVG Cleaner top features:
✔ Uninstall Updates of Preinstalled Apps: replace preinstalled bloatware apps you don't use with factory versions to save space
✔ Get more space - Remove junk files, uninstall apps, and delete bad or unwanted photos and videos
✔ System info - Everything you need to know about your phone on one screen
✔ File manager - Smart File Manager & Storage Cleaner can analyze pictures, files, and apps
✔ Junk Cleaner - Clean out any useless junk from your device e.g. app data
With AVG Cleaner, you will get rid of junk files, and automatically find bad quality or duplicate photos
AVG Cleaner – Storage Cleaner is a clean up tool that gives you more storage space
Junk cleaner, storage clean up, and app removal features are described below:
Cleaner: Advanced app remover & app manager:
► App analyzer: AVG Cleaner can identify apps that drain mobile data, or take up too much storage space, allowing you to clean them out more easily
► App remover: Easily remove apps to get more storage space
► Junk cleaner: Master junk files and leftover data
► Easily analyze apps based on storage, ram, battery, data consumption or usage
Cleaner: Photo Analyzer:
► Find bad quality or duplicate photos
► Easily clean your photo library
Cleaner: 1-tap Analysis
► Clean your device with a single tap of a button
► Perform device scan and analysis with just one tap
Media Overview
• Access Image Analysis results
• Sorted media by source folders
• All large video files in one view
App Overview
• Draining apps analysis
• Usage statistics
• App size growth analysis
• Notification analysis
Clean your phone to free up storage space. Eliminate junk, delete bad quality, similar or duplicate photos to make more storage space available for the apps, photos, and other stuff you want.
What New:
We are always working to maintain this app in tip top shape and improve its functionalities. To learn details about the most important recent changes, please open the app and navigate to "What's new" screen. It can be directly accessed from the main menu. Thank you for using our app!
9.0 and up
Home Page :
AVG Cleaner – Storage Cleaner - Apps on Google Play
Clean your phone and remove hidden junk from storage with our master cleaner app
![ztJM1dp.gif](https://i.postimg.cc/L4LdsnGG/ztJM1dp.gif)
