Camtasia Studio - có thể kết hợp hoặc chia nhỏ clip, cắt và tăng tốc hoặc làm chậm hình ảnh. Và xem trước chúng ngay lập tức trong trình chỉnh sửa video. Nó giúp video trông rất chuyên nghiệp, được các Youtuber và các biên tập viên chuyên nghiệp ưa chuộng. Nó đi kèm với một giao diện rất đơn giản. Với các công cụ và chức năng chỉnh sửa video mạnh mẽ.
Create professional, eye-catching videos:
- Add special video effects - Apply Behaviors that are perfectly designed to animate your text, images, or icons. Get a crisp, polished look without being a professional video editor.
- Drag-and-drop your edits - What you see is what you get. Every effect and element in your video can be dropped and edited directly in the preview window. And you can edit at resolutions up to beautiful 4K, for clear video at any size.
- Get exceptional performance - Camtasia takes full advantage of your computer’s processor with 64-bit performance. You’ll get fast rendering times and enhanced stability—even on your most complex projects.
17 June, 2022: Camtasia (Windows) 2022.0.2
- Added subscription information to the About Camtasia dialog.
- Added Blending Range control to Color Adjustment effect.
- Added Blending Range control to Color LUT effect.
- Added Blending Range control to Color Tint effect.
- Added Blending Range control to Colorize effect.
- Renamed Colorize Amount property to Intensity for consistency with other effects.
- Added better error handling when media files become unavailable.
- Fuse error dialogs now link directly to a relevant help article.
- Fixed a crash that could occur during batch production if a .tscproj file was invalid
- Fixed a crash that could occur when a Library asset was missing key information.
- Fixed a crash that could occur when grouping stitched media with no visual track.
- Fixed a crash that could occur when Camtasia is shutting down.
- Fixed a bug that could prevent exporting from Audiate to Camtasia.
Homepage: https://www.techsmith.com
Download:
https://download.techsmith.com/camtasiastudio/releases/camtasia.exe
https://download.techsmith.com/camtasiastudio/releases/2202/camtasia.exe
https://download.techsmith.com/camtasiastudio/releases/2202/camtasia.zip
https://download.techsmith.com/camtasiastudio/releases/2202/camtasia.msi
Hoặc Link tải khác :
