System Ninja Pro v.4.0.1 Multilingual Portable | VN-Zoom | Cộng đồng Chia Sẻ Kiến Thức Công Nghệ và Phần Mềm Máy Tính
We don't have any banner, Flash, animation, obnoxious sound, .... We do not implement these annoying types of ads!
System Ninja portable is a fast, powerful and effective system optimization solution for Windows. It’s designed to quickly remove junk files, improve system speed and help fix problems. System Ninja is a program for cleaning your computer of unwanted junk that constantly slows your entire system down. Apart from the useful file cleaner, the program also has a Startup Manager, Process Manager and P3P Registry History cleaning tool.
Feature Overview
Powerful Junk Cleaner
System Ninja contains a unique dual cleaning engine. It scans your entire hard drive performing a thorough initial scan, identifying junk based on heuristics. System Ninja then continues to check locations that are known to contain junk based on a number of routines.
Useful Startup Management
The integrated startup manager allows you to dictate what can and can’t run when you turn on your computer. It supports Run, RunOnce and Sheduled Tasks files and registry keys. System Ninja contains a database of several hundred common startup items, used to provide information and advice so you know what to remove.
Powerful Process Manager
The process manager can forcibly terminate any process running on your computer. It can even remove multiple processes simultaneously.
Turbocharged With CleanSync
CleanSync is a new system added in version 2.1 that silently downloads new cleaning routines while System Ninja is running.
Supports Winapp2.ini (included)
Winapp2.ini is a collection of cleaning routines that adds cleaning support for over one thousand additional programs. It’s supported by all major Windows cleaning apps, including CCleaner and BleachBit.
Available in multiple languages
System Ninja is currently available in English, Dutch, Spanish, French, Swedish, Vietnamese, Polish, Italian, German, Russian and Brazilian. We’re always looking for new translators!
Whats New:
System Ninja 4.0 is now available. This release brings a redesigned user interface, full support for Windows 11, support for high resolution displays, plus countless bug fixes and usability improvements.
What’s new in System Ninja 4.0.1:
  • Context menus can now be translated
  • Fixed an issue with poor window scaling on the Drive Selector dialog
  • Fix issues with high DPI scaling on the DuplicateFinder tool
  • Updated the French, Slovenian and Russian translations
  • The system analysis tool will now correctly detect the Windows version number
  • For pro users, Custom Branding can now change internal website links
  • The window title of various dialog boxes can now be translated
Title Release: System.Ninja.v.4.0.1
Developer: Home Page
License: FreeWare
System Ninja Pro v.4.0 Portable - New Update Version
System Ninja Pro v.4.0.1 Portable - New Update Version
