EximiousSoft Banner Maker Pro v.5.20 Portable | VN-Zoom | Cộng đồng Chia Sẻ Kiến Thức Công Nghệ và Phần Mềm Máy Tính
EximiousSoft Banner Maker Pro is quite a powerful program for creating advertising banners, web buttons, headers and other web graphics. The software supports the creation of layers for each element of the created web graphics. Raster images and vector shapes can be used to create graphics.
The program has pre-prepared gradients of various styles and background images for filling forms and text objects. The program does not require any knowledge in creating web graphics and can be perfect for beginners who need to quickly make a banner for their site or web button.
Key features:
• Support for creating layers• Import bitmaps or vector shapes
• Fill text and vector shapes
with gradients and backgrounds• Apply shadows, bumps, textures and other effects to objects• Support for animated GIF files
• Create animations with effects in one step
• Export the result to JPEG, GIF and PNG formats
• Preview the result in the built-in browser
• Easy-to-use interface
• Add and remove frames in animations
• Undo and redo actions at any time
Home Page : http://www.eximioussoft.com
For more infomation to download , Please contact @Shao
EximiousSoft Banner Maker Pro v.5.15 - New Update Version
EximiousSoft Banner Maker Pro v.5.20 Portable - New Update Version
Bài Viết Mới
