Chia sẻ - Plugin Elementor Pro Websites Builder 3.21.2 - Plugin tạo trang web hàng đầu trên Wordpress | Page 2 | VN-Zoom | Cộng đồng Chia Sẻ Kiến Thức Công Nghệ và Phần Mềm Máy Tính
Chia sẻ Plugin Elementor Pro Websites Builder 3.21.2 - Plugin tạo trang web hàng đầu trên Wordpress
hungnth
Update Elementor Pro 3.14 - 21/06/2023
Link download
Change log:
# Elementor Pro - by Elementor.com
#### 3.14.0 - 2023-06-19
* New: Introducing Carousel widget - Infinite design possibilities, and nesting capabilities ([#2587](https://github.com/elementor/elementor/issues/2587), [#219](https://github.com/elementor/elementor/issues/219))
* Tweak: Added Static Item Position functionality to Alternate template in Loop Grid widget
* Tweak: Added visual indication of Page Parts
* Tweak: Added dividers option between menu items in Menu widget
* Tweak: Changed the HTML structure of Pagination and Navigation in Loop Carousel and Nested Carousel widgets
* Tweak: Added shop page in WooCommerce Pages section in Site Settings
* Tweak: Added Text Shadow, Box Shadow and Padding control to button in Call to Action widget
* Tweak: Added Lazy Load support for images in Video Playlist widget
* Tweak: Added `alt` attribute to images in Video Playlist widget
* Tweak: Replaced select control with choose control for Flip Direction control in Flip Box widget
* Tweak: Added keyboard accessibility to Carousel and Loop Carousel widgets
* Tweak: Use `media_types` array in Media controls
* Fix: Lightbox is still enabled after disabling it in the Site Settings in Gallery widget ([#11193](https://github.com/elementor/elementor/issues/11193), [#19871](https://github.com/elementor/elementor/issues/19871))
* Fix: Responsive settings for templates don't work as expected when Additional Custom Breakpoints feature is active ([#16819](https://github.com/elementor/elementor/issues/16819), [#19394](https://github.com/elementor/elementor/issues/19394))
* Fix: Inner containers are not presented as expected in Menu widget ([#21813](https://github.com/elementor/elementor/issues/21813))
* Fix: Popup width does not support percentages ([#22413](https://github.com/elementor/elementor/issues/22413))
* Fix: PHP 8.x throws errors when using WooCommerce Ajax response ([#22199](https://github.com/elementor/elementor/issues/22199))
* Fix: Mini cart template appears as empty in various scenarios in Menu Cart widget ([#22789](https://github.com/elementor/elementor/issues/22789))
* Fix: Order by Price doesn't work for the Latest products or Manual Selection in Products widget
* Fix: Dropdown indicator icon is not vertically aligned to the text when using icon in Menu Widget
* Fix: Mixed content warning in the console for Video Playlist widget
* Fix: Preview settings are not presented as expected after first save in Loop Template
* Fix: Not-crawlable link error in Video Playlist widget
* Fix: Lightbox is still enabled after disabling it in the Site Settings in Logo widget
* Fix: Focus state issue on page load when using Table of Content widget
hungnth
Update Elementor Pro 3.14.1 - 27/06/2023
Link download
Change log:
#### 3.14.1 - 2023-06-26
* Tweak: Improved navigation on touch devices in Carousel widget ([#22827](https://github.com/elementor/elementor/issues/22827))
* Fix: Missing navigation arrows on lightbox in Gallery widget ([#22870](https://github.com/elementor/elementor/issues/22870))
hungnth
Update Elementor Pro 3.15.0 - 05/08/2023
Link download
Change log:
#### 3.15.0 - 2023-07-31
* New: Introducing Taxonomy Filter widget - Empower visitors to seamlessly filter listings in Loop Grids based on taxonomies ([#3140](https://github.com/elementor/elementor/issues/3140))
* Tweak: Added an "Offset Sides" functionality in Carousel and Loop Carousel widgets ([#21114](https://github.com/elementor/elementor/issues/21114))
* Tweak: Modified the size of the Publish button in the Editor Top Bar feature ([#22472](https://github.com/elementor/elementor/issues/22472))
* Tweak: Improved Ajax permissions functionality for better security enforcement
* Tweak: Added option for pagination custom position in Carousel and Loop Carousel widgets
* Tweak: Added option for navigation custom position in Carousel and Loop Carousel widgets
* Tweak: Added additional styling options for navigation in Carousel and Loop Carousel widgets
* Tweak: Added labels to shortcode column in WordPress admin
* Tweak: Unified the appearance of `stretch` and `center` buttons in Menu widget
* Tweak: Unified the appearance of `stretch` and `center` buttons in My Account widget
* Tweak: Improved panel UI in Video Playlist widget
* Tweak: Implemented CSS logical properties in Elementor Editor
* Tweak: Added "Title HTML Tag" and "Description HTML Tag" in Price List widget
* Tweak: Added "Title HTML Tag" and "Description HTML Tag" in Slides widget
* Tweak: Added "Title HTML Tag" and "Description HTML Tag" in Flip Box widget
* Tweak: Added "Description HTML Tag" in Call To Action widget
* Security Fix: Improved code security enforcement in Share Buttons widget
* Security Fix: Improved code security enforcement in Form widget
* Fix: WooCommerce Status page failed to recognize Elementor WooCommerce widgets
* Fix: Pagination does not work inside single templates when using Posts and Loop Grid widgets
* Fix: Incorrect saving of WooCommerce page settings in Elementor site settings under certain scenarios
dongninh
Cảm ơn tác giả đã update cho ae
hungnth
Update Elementor Pro 3.16 - 12/09/2023
Link download
Link 1:
Link 2:
Change log:
#### 3.16.0 - 2023-09-12
* Tweak: Implemented accessibility improvements in Menu widget ([#23607](https://github.com/elementor/elementor/issues/23607), [#22554](https://github.com/elementor/elementor/issues/22554))
* Fix: 'Fallback: Recent Posts' option malfunctions in the Query control ([#21436](https://github.com/elementor/elementor/issues/21436), [#23259](https://github.com/elementor/elementor/issues/23259))
* Tweak: Hide navigation arrows when there is only one slide in the Loop or Nested carousel ([#22056](https://github.com/elementor/elementor/issues/22056))
* Tweak: Used appropriate image `alt` in Testimonial Carousel widget ([#17680](https://github.com/elementor/elementor/issues/17680))
* Tweak: Optimized Scroll Snap functionality when using Container widget
* Tweak: Enhanced Elementor Role Manager functionality when using Containers
* Tweak: Added Notes feature to the Editor Top Bar
* Tweak: Replace CSS `float` with other layouts in the Editor
* Tweak: Upgraded HTML Structure for the Menu widget
* Tweak: Implemented CSS logical properties in Carousel and Menu widgets
* Tweak: Added keyboard accessibility to a link in Posts widget
* Tweak: Loop Builder feature merged to version
* Fix: Addressed inconsistency in hover effect durations between icon, dropdown indicator colors, and text colors in the Menu widget ([#22376](https://github.com/elementor/elementor/issues/22376))
* Fix: Slides break if the parent container is set to HTML A tag in Loop Carousel and Carousel widgets ([#22678](https://github.com/elementor/elementor/issues/22678))
* Fix: The icon size setting is not affecting uploaded SVG icons in the Menu widget ([#22372](https://github.com/elementor/elementor/issues/22372))
* Fix: Taxonomy filter does not work with slug in foreign characters ([#23315](https://github.com/elementor/elementor/issues/23315))
* Fix: Improved code security enforcement in Dynamic Tags
hungnth
Update Elementor Pro 3.16.1 - 18/09/2023
Link download
Link 1:
Link 2:
Change log:
* Fix: Dynamic tag for ACF image field is not working as expected ([#23757](https://github.com/elementor/elementor/issues/23757))
* Fix: Sticky functionality affects padding values in Container ([#23758](https://github.com/elementor/elementor/issues/23758))
* Fix: HTML list issues for padding and margin in Menu widget
hungnth
Update Elementor Pro 3.16.2 - 22/09/2023
Link download
Link 1:
Link 2:
Change log:
#### 3.16.2 - 2023-09-20
* Fix: Fit to Content dropdown position calculation is incorrect in Menu widget ([#23808](https://github.com/elementor/elementor/issues/23808))
* Fix: Reverted hide navigation arrows when there is only one slide in the Loop or Nested carousel ([#23804](https://github.com/elementor/elementor/issues/23804))
hungnth
Update Elementor Pro 3.18.1 - 07/12/2023
Link download
Link 1:
Link 2:
Change log:
#### 3.18.1 - 2023-12-06
* Fix: No results appeared when reloading the page with deep link and de-selecting terms in Taxonomy Filter widget
* Fix: No results appeared when filtering the Uncategorized category in Filter Taxonomy widget
* Fix: Notes still available when the Notes feature is deactivated
lamhunglq
Elementor là Plugin Page Builder giúp bạn tạo các trang WordPress đẹp mắt một cách dễ dàng. Chỉ với các thao tác kéo thả đơn giản là bạn đã sở hữu được một Website theo ý muốn. Vì vậy, với Elementor các bạn không rành về Code cũng có thể tạo được Website cho riêng mình.
Mục đích của Elementor là giúp cho những bạn không biết gì về lập trình có thể tự xây dựng Website tuyệt đẹp cho chính mình. Thay vì những tính năng cơ bản như thêm hình ảnh, thêm chữ như ở WordPress Editor. Elementor sẽ giúp bạn tạo các Layout với các hàng và cột để dễ dàng, tối ưu hơn. Với phiên bản Elementor Pro, bạn sẽ thoải mái xây dựng Page Contact, Homepage hay giới thiệu sản phẩm. Nó sẽ giúp bạn thoải mái sáng tạo và tự thiết kế Website theo ý muốn của mình.
Lưu ý: Elementor Pro mình chia sẻ ở đây đã được kích hoạt trước và chỉ cần cài đặt là sử dụng. Được khuyến khích dùng cho mục đích vọc vạch, tìm hiểu về làm website bằng Elementor. Nếu có điều kiện hãy mua bản quyền để ủng hộ tác giả.
Trang chủ
Link download (mã hex)
Hướng dẫn download
Copy đoạn mã hex phía trên > paste vào 1 trong 2 công cụ phía dưới và convert để lấy link download
Web chuyển đổi online
Chrome extension
Nếu có phiên bản mới mình sẽ cập nhật ở comment nhé.
Update Elementor Pro 3.11.6
Change log:
68747470733a2f2f7777772e64726f70626f782e636f6d2f732f6469306d32766f326a327375676c6f2f5072652d4163746976617465642d656c656d656e746f722d70726f2d332e31312e312e7a69703f646c3d31
lamhunglq
hungnth
Update Elementor Pro 3.18.3 - 18/01/2024
Link download
Link 1:
Link 2:
Change log:
#### 3.18.3 - 2024-01-17
* Fix: Improved code security enforcement in Table of Contents widget
* Fix: Improved code security enforcement in Countdown widget
* Fix: Kit is not being deleted when using Remove Kit feature
