General
Unique ID : 247768661579783997357481217788725737577 (0xBA66822A8C318A638B86E603572CB869)
Complete name : E:\Video\Dragon Ball GT\Season 1\Dragon.Ball.GT.S01E01.(01).A.Devastating.Wish.1080p.DVD.Remux.Upscale.FLAC.2.0.AVC.mkv
Format : Matroska
Format version : Version 4
File size : 5.74 GiB
Duration : 24 min 40 s
Overall bit rate mode : Variable
Overall bit rate : 33.3 Mb/s
Encoded date : UTC 2022-03-23 10:17:16
Writing application : mkvmerge v64.0.0 ('Willows') 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Attachments : FaxfontTone.otf / Funimitation.ttf / FunimitationBoldItalic.ttf / Oravetica Normal (! sq-sq).ttf / Wolf Sans Regular (!rd-rd).ttf / Caballar (s).ttf / FaxfontStandard.otf
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 24 min 38 s
Bit rate mode : Variable
Bit rate : 30.0 Mb/s
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.805
Stream size : 5.16 GiB (90%)
Writing library : x264 core 157 r2969 d4099dd
Encoding settings : cabac=1 / ref=4 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.01 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=16 / lookahead_threads=1 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=1 / keyint=24 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=crf / mbtree=1 / crf=1.0 / qcomp=0.80 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=30000 / vbv_bufsize=30000 / crf_max=0.0 / nal_hrd=vbr / filler=0 / ip_ratio=1.10 / aq=1:0.50
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Bit rate : 414 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 11.719 FPS (4096 SPF)
Bit depth : 16 bits
Compression mode : Lossless
Stream size : 73.0 MiB (1%)
Title : Broadcast Audio / Japanese / 2.0 Stereo / FLAC [Deli]
Writing library : libFLAC 1.3.1 (UTC 2014-11-25)
Language : Japanese
Default : Yes
Forced : No
Audio #2
Format : FLAC
Codec ID : A_FLAC
Bit rate : 721 kb/s
Frame rate : 10.417 FPS (4608 SPF)
Bit depth : 16 bits
Stream size : 127 MiB (2%)
Title : FUNimation Original Dub Audio / English / 2.0 Stereo / FLAC [iKaos]
Writing library : Lavf58.76.100
Language : English
Default : No
Forced : No
Audio #3
Format : FLAC
Codec ID : A_FLAC
Bit rate : 704 kb/s
Bit depth : 16 bits
Stream size : 124 MiB (2%)
Title : FUNimation Remastered Dub (Menza Score) Audio / English / 2.0 Stereo / FLAC [iKaos]
Language : English
Default : No
Forced : No
Audio #4
Format : FLAC
Codec ID : A_FLAC
Bit rate : 1 090 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Bit depth : 16 bits
Stream size : 192 MiB (3%)
Title : FUNimation Remastered Dub (Tokunaga Score) Audio / English / 5.1 Surround / FLAC [vanner64]
Language : English
Default : No
Forced : No
Audio #5
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Duration : 24 min 37 s
Bit rate mode : Constant
Bit rate : 448 kb/s
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 78.9 MiB (1%)
Title : R2J Dragon Box Audio / Japanese / 2.0 Stereo / AC-3 [mgold0704]
Language : Japanese
Service kind : Complete Main
Default : No
Forced : No
Text #1
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Duration : 24 min 34 s
Bit rate : 85 b/s
Count of elements : 257
Stream size : 15.4 KiB (0%)
Title : Animelabs Fansubs / English / ASS [Animelabs & brap]
Language : English
Default : No
Forced : No
Text #2
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 24 min 32 s
Bit rate : 67 b/s
Count of elements : 340
Stream size : 12.2 KiB (0%)
Title : Basic Subtitles / English / SRT [iKaos & Isaac]
Language : English
Default : No
Forced : No
Text #3
Format : ASS
Duration : 24 min 33 s
Bit rate : 142 b/s
Count of elements : 421
Stream size : 25.6 KiB (0%)
Title : English Dubtitles / English / ASS [mgold0704 & OnionEclipse]
Language : English
Default : No
Forced : No
Text #4
Format : ASS
Bit rate : 136 b/s
Count of elements : 390
Stream size : 24.6 KiB (0%)
Title : Stylized Subtitles / English / ASS [corre, sangofe & iKaos]
Language : English
Default : Yes
Forced : No
Text #5
Format : ASS
Bit rate : 57 b/s
Count of elements : 129
Stream size : 10.3 KiB (0%)
Title : Stylized Subtitles (OP, ED, Titles, Inserts, NEPs) / English / ASS [corre & iKaos]
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Opening
00:01:48.108 : en:Part A
00:11:54.380 : en:Part B
00:22:31.851 : en:Ending
00:24:07.947 : en:Next Episode Preview
