PM Việt hóa & Portable - Sound Normalizer v.8.7 + Portable | VN-Zoom | Cộng đồng Chia Sẻ Kiến Thức Công Nghệ và Phần Mềm Máy Tính
PM Việt hóa & Portable Sound Normalizer v.8.7 + Portable
The Sound Normalizer reduce, improves, regains a volume and a file size without losing ID3, FLAC, Ogg, Mp4 Tags of Mp3, Mp4 (AAC, ALAC), FLAC, Ogg, APE, Wav (PCM 8, 16, 24, 32 bits, DSP, GSM, IMA ADPCM, MS ADPCM, AC3, MP3, MP2, OGG, A-LAW, u-LAW) files. It is reached by the test and normalization of the volume level of Mp3, Mp4 (AAC, ALAC), FLAC, Ogg, APE and Wav files.
The Sound Normalizer contains batch processor and it allows to fulfill the batch test, batch normalization and batch converting Mp3, Mp4 (AAC, ALAC), FLAC, Ogg, APE, Wav files.
The Sound Normalizer allows to fulfill the test, and normalization separately for each channel (Left, Right).
Volume normalization is fulfilled with help of the Mp3, Mp4, Wav, FLAC, Ogg, APE, AAC, ALAC Normalizer.
The volume level is represented graphically in percentage or decibels (dB).
The Mp4 (AAC, ALAC), FLAC, Ogg, APE, Wav normalization and test is fulfilled on a peak level (Peak Normalization) and on an average level (RMS normalization). The Mp3 normalization and test is fulfilled on an average level (RMS normalization).
The Mp3 Normalizer allows to modify a volume of a scanned file directly without usage Mp3 Encoder and APEv2 tags.
The Sound Normalizer also allows editing ID3, Mp4, FLAC, Ogg Tags, converting FLAC to Mp3 (with saving ID3, FLAC tags), Wav to Mp3, Mp3 to Wav, Mp3 to Mp3 (with saving ID3 tags), Wav to MP4 (AAC, ALAC), Wav to AAC, MP4 (AAC, ALAC) to Wav, MP4 (AAC) to MP4 (AAC), Wav to APE, APE to Wav, APE to Ogg, Wav to Ogg, Ogg to Mp3, Ogg to Wav files using Lame MP3 Encoder 3.100, FLAC Encoder 1.3.3, Monkey’s Audio Encoder 8.36, Ogg Vorbis Encoder 1.3.7, FAAC Encoder 1.30, ALAC Encoder 2011 from Apple, listening Mp3, Mp4 (AAC, ALAC), FLAC, Ogg, APE and Wav files using the built-in audio player.
Here are some key features of "Sound Normalizer":
  • Mp3, Mp4 (AAC, ALAC), FLAC, Ogg, APE, Wav (PCM 8, 16, 24, 32 bits, DSP, GSM, IMA ADPCM, MS ADPCM, AC3, MP3, MP2, OGG, A-LAW, u-LAW) Normalizer;
  • Batch Processor (Batch Test, Batch Normalizing, Batch Converting) for Mp3, Mp4 (AAC, ALAC), FLAC, Ogg, APE, Wav (PCM 8, 16, 24, 32 bits, DSP, GSM, IMA ADPCM, MS ADPCM, AC3, MP3, MP2, OGG, A-LAW, u-LAW) files;
  • Reduction of size files Mp3, Mp4 (AAC), Wav, Ogg, APE, FLAC;
  • Converting Mp3 to Wav (PCM 8, 16, 24, 32 bits, DSP, GSM, IMA ADPCM, MS ADPCM, AC3, MP3, MP2, OGG, A-LAW, u-LAW) files;
  • Converting Wav (PCM 8, 16, 24, 32 bits, DSP, GSM, IMA ADPCM, MS ADPCM, AC3, MP3, MP2, OGG, A-LAW, u-LAW) to Mp3 files using Lame MP3 Encoder 3.100;
  • Converting Mp4 (AAC, ALAC) to Wav (PCM 8, 16, 24, 32 bits, DSP, GSM, IMA ADPCM, MS ADPCM, AC3, MP3, MP2, OGG, A-LAW, u-LAW) files;
  • Converting Wav (PCM 8, 16, 24, 32 bits, DSP, GSM, IMA ADPCM, MS ADPCM, AC3, MP3, MP2, OGG, A-LAW, u-LAW) to Mp4 (AAC, ALAC) files using FAAC Encoder 1.30 and ALAC Encoder 2011 from Apple;
  • Converting Mp3 to Mp3 files using Lame MP3 Encoder 3.100;
  • Converting Wav (PCM 8, 16, 24, 32 bits, DSP, GSM, IMA ADPCM, MS ADPCM, AC3, MP3, MP2, OGG, A-LAW, u-LAW) to APE files using Monkey’s Audio Encoder 8.36;
  • Converting APE to Wav (PCM 8, 16, 24, 32 bits, DSP, GSM, IMA ADPCM, MS ADPCM, AC3, MP3, MP2, OGG, A-LAW, u-LAW);
  • Converting Wav (PCM 8, 16, 24, 32 bits, DSP, GSM, IMA ADPCM, MS ADPCM, AC3, MP3, MP2, OGG, A-LAW, u-LAW) to FLAC files using FLAC Encoder 1.3.3;
  • Converting FLAC to Wav (PCM 8, 16, 24, 32 bits, DSP, GSM, IMA ADPCM, MS ADPCM, AC3, MP3, MP2, OGG, A-LAW, u-LAW);
  • Converting FLAC to Mp3 files using Lame MP3 Encoder 3.100;
  • Converting FLAC to MP4/AAC files using FAAC Encoder 1.30;
  • Converting APE to Mp3, files using Lame MP3 Encoder 3.100;
  • Converting APE to Ogg files using Ogg Vorbis Encoder 1.3.7;
  • Converting APE to MP4/AAC files using FAAC Encoder 1.30;
  • Converting MP4/AAC to MP4/AAC files using FAAC Encoder 1.30;
  • Converting FLAC to Ogg files using Ogg Vorbis Encoder 1.3.7;
  • Converting Wav (PCM 8, 16, 24, 32 bits, DSP, GSM, IMA ADPCM, MS ADPCM, AC3, MP3, MP2, OGG, A-LAW, u-LAW) to Ogg files using Ogg Vorbis Encoder 1.3.7;
  • Converting Ogg to Wav (PCM 8, 16, 24, 32 bits, DSP, GSM, IMA ADPCM, MS ADPCM, AC3, MP3, MP2, OGG, A-LAW, u-LAW) files;
  • Support various encoder quality/speed modes;
  • Extensive encoder options;
  • Support pre-listen audio file;
  • Support Mp4, FLAC, Ogg, ID3 v1 and v2 tag (Artist/Title/Genre and so on).
Requirements:
  • Sound Card;
  • Administrative permissions.
OS Supported:
  • Windows Vista/7/8/10 x86|x64.
October 8, 2022
Sound Normalizer 8.7 released!
What is New
Improved Batch Processor.
Added function to determine the size of normalized files.
Home Page :
mienhanh
Cám ơn bạn nhiều.
