hnam31190
Collection Serie Film Cartoon của mình 2023 ^ ^ Cố gắng sẽ cover toàn bộ các phim đã phát trên TV từ xưa đến giờ
Chúc anh em và gia đình có thời gian vui vẻ !!
#01: Tom & Jerry
#02: Scooby Doo
#03: Spongebob Squarepants
#04: Courage the Cowardly Dog
#05 Paw Patrol
#06 PJ Masks
#07 Looney Tunes
#08 Flintstones
#09 Teen Titans
#10 Teen Titans Go!
#11 Shaun The Sheep
#12 Powerpuff Girls
#13 Super Wings
#14 Rick and Morty
#15 Pokemon
#16 Ed Edd Eddy
Giới thiệu:
List Episodes
INFO:
#01: Tom & Jerry
#02: Scooby Doo
#05 Paw Patrol
#06 PJ Masks
#07 Looney Tunes
#08 Flintstones
#09 Teen Titans
#10 Teen Titans Go!
#11 Shaun The Sheep
#12 Powerpuff Girls
#13 Super Wings
#14 Rick and Morty
#15 Pokemon
#16 Ed Edd Eddy
Giới thiệu:
List Episodes
INFO:
General
Unique ID : 218790298897585488252807148140046939952 (0xA4997A93DEECC79F992FA296710D7730)
Complete name : G:\New Folder\Phineas and Ferb\Phineas and Ferb - S01E05-E06 - The Magnificent Few SWinter (1080p WEB-DL x265 HEVC 10bit AAC 2.0 RCVR) [UTR].mkv
Format : Matroska
Format version : Version 4
File size : 199 MiB
Duration : 22 min 41 s
Overall bit rate : 1 228 kb/s
Encoded date : UTC 2017-02-07 14:22:54
Writing application : mkvmerge v9.6.0 ('Slave To Your Mind') 64bit
Writing library : libebml v1.3.4 + libmatroska v1.4.5
Cover : Yes
Attachments : cover.jpg
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L4@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 1 088 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.022
Stream size : 177 MiB (89%)
Writing library : x265 2.2+23-58dddcf01b7d:[Windows][MSVC 1910][64 bit] 10bit
Encoding settings : cpuid=1173503 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=32639 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=50 / lookahead-slices=4 / scenecut=40 / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=5 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=-1:-1 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=1.00 / psy-rdoq=1.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=1087 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=0.55 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion
Default : Yes
Forced : No
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Bit rate : 137 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 22.2 MiB (11%)
Language : English
Default : No
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 22 min 31 s
Bit rate : 111 b/s
Frame rate : 0.355 FPS
Count of elements : 480
Stream size : 18.4 KiB (0%)
Language : English
Default : No
Forced : No
