hnam31190
Sau khi đã lên full các bộ cartoon US, mình sẽ lên tiếp các bộ Anime trong những ngày trước tết - Đều là những bản special Version, được Upscale lên 1080p đẹp hơn cả source gốc
- Dragon Ball
- Dragon Ball GT
- Dragon Ball Z
- Dragon Ball Kai
- Dragon Ball Super
SCREENSHOT
SOURCE:
INFO bản x264 - Version được share đã được chuyển về x265
- Dragon Ball GT
- Dragon Ball Z
- Dragon Ball Kai
- Dragon Ball Super
SCREENSHOT
SOURCE:
DRAGON BALL: DRAGON BOX SET
General
Unique ID : 290808300089632716515378135677499079718 (0xDAC7A42DABFF1555655FCF3EB3E7FC26)
Complete name : E:\Dragon Ball\Season 1\Dragon Ball - S01E01 - Secret of the Dragon Balls.mkv
Format : Matroska
Format version : Version 4
File size : 700 MiB
Duration : 24 min 12 s
Overall bit rate : 4 041 kb/s
Encoded date : UTC 2018-10-12 17:30:23
Writing application : mkvmerge v27.0.0 ('Metropolis') 64-bit
Writing library : libebml v1.3.6 + libmatroska v1.4.9
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings : 4 Ref Frames
Format settings, CABAC : No
Format settings, Reference frames : 4 frames
Format settings, GOP : M=4, N=18
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 3 500 kb/s
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.094
Stream size : 605 MiB (86%)
Writing library : x264 core 148
Encoding settings : cabac=0 / ref=2 / deblock=1:0:0 / analyse=0x3:0x100 / me=dia / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=1 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=0 / b_bias=0 / direct=1 / weightb=1 / open_gop=1 / weightp=2 / keyint=18 / keyint_min=10 / scenecut=0 / intra_refresh=0 / rc_lookahead=18 / rc=abr / mbtree=1 / bitrate=3500 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=9000 / vbv_bufsize=1835 / nal_hrd=none / filler=0 / ip_ratio=1.41 / aq=1:1.00
Default : Yes
Forced : No
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Delay relative to video : 183 ms
Stream size : 77.6 MiB (11%)
Title : Surround
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Bit rate : 96.0 kb/s
Channel(s) : 1 channel
Channel layout : C
Delay relative to video : 33 ms
Stream size : 16.6 MiB (2%)
Title : Mono
Language : Japanese
Default : No
Forced : No
Text #1
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Codec ID/Info : Picture based subtitle format used on DVDs
Duration : 466 ms
Bit rate : 17.1 kb/s
Count of elements : 1
Stream size : 996 Bytes (0%)
Language : English
Default : No
Forced : No
Text #2
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Duration : 23 min 50 s
Bit rate : 4 113 b/s
Count of elements : 277
Stream size : 718 KiB (0%)
Language : English
Default : No
Forced : No
Menu
00:00:00.125 : :Chapter 1
00:01:50.277 : :Chapter 2
00:02:30.359 : :Chapter 3
00:12:03.890 : :Chapter 4
00:22:34.395 : :Chapter 5
