hiennvl12
Rìu Sắt Đôi
Mình lên mạng có thấy sự xuất hiện cái tên Multi OEM/Retail Project Build 12.08.2020
chưa hiểu cái dự án kích hoạt cho bán lẻ này lắm
rất mong các Mod cho mình được hiểu thêm về nó
thông tin nó có ngay bên dưới đó ạ.
Thông tin được viết bằng Tiếng Anh
Multi OEM/Retail Project – included 100+ OEM’s: • Acer • Advent • Action • Alienware • AOC • Aquarius • ASRock • Asus • ATcomputers • Bangho • Beko • BenQ • BGH-SA • ByteSpeed • Casper • CCE • chiliGREEN • Compaq • crea • CZC • Dell • Depo • digimix • ECS • eMachines • Epson • Equus • Everex • Excimer • EXO • Exper • Extra • Founder • FSC • Fujitsu • Gateway • Genuine • Gericom • Gigabyte • Greatwall • Haier • Hannspree • Hasee • HCL • Hedy • Higrade • HP • Hyrican • IBM • Impression • Infinity • Insys • Intelbras • iQon • Itautec • Jetway • JooyonTech • Kohjinsha • Kouziro • Kraftway • KSystems • Lanix • Lenovo • LG • M&A Technology • Maxdata • Mecer • Medion • Megaware • Mesh • Mitac • Mouse • MSI • NEC • Nokia • Olidata • Olivetti • Onkyo • OQO • Packard Bell • Panasonic • Paradigit • Paragon • Philco • Positivo • PowerSpec • Prolink • qbex • Quanmax • RMplc • Rover • Samsung • SCC • Semp Toshiba • Seneca • Sharp • Sony • Stone • Synnex • Systemax • Tangent • Targa • Tarox • TCL • TTL • Tongfang • Toshiba • Trigem • Twinhead • Velocity • Vestel • Viewsonic • viliv • WD Corporation • Wortmann • xplore • Zoostorm • ZT ~incl. (branding only): BioStar • Foxconn • Intel • M$ $urface • VirtualBox • VMware
OEM’s Branded = 133~
• BIOS Mode supported: Legacy and/or UEFI
• You can force install ‘ANY’ brand theme by reading and using the Force_Theme_[readme].txt
Editions for OEM Activation
• Server 2008 • Server 2008 R2 • Server 2012 • Server 2012 R2
• Win10… • Home • Pro
• Win8.x… • Core • Pro
• Win7….. • Starter • Home Basic • Home Premium • Pro • Ultimate
• Vista….. • Starter • Home Basic • Home Premium • Business • Ultimate
Objective – add $oem$ folder to .iso /usb.
• $oem$ method can be used to apply activation & manufacturer brand to your Win10 • Win 8.x • Win 7 • Vista ‘.iso’/usb
• NOTE:- PC needs (Win8.x and Win10 ‘OEM--censor-’ • Win7 ‘2.1 slic’ • Vista ‘2.0 slic’) bios to apply genuine oem activation.
• Project includes optional Telemetry disabling, (WinTel.cmd), for all supported OS’s and adds domains to block through Route commands.
How To:
Win8.x|Win10
Place the downloaded ‘$oem$’ folder in the ‘sources’ folder of your ‘clean’ iso, and add custom ‘ei.cfg’ file to the same ‘sources’ folder and edit|save iso. Windows will install the edition identified from ‘ei.cfg’ file. (Project ‘Options’ folder includes ‘ei.cfg’ instructions). OOBE.cmd will call tool that will extract embedded ‘OEM--censor-’ key from bios (if exists), and apply the serial during installation.
Win7
Place the downloaded ‘$oem$’ folder in the ‘sources’ folder of your ‘clean’ iso, and delete the ‘ei.cfg’ file from the same ‘sources’ folder and edit|save iso… during install you will have option to select the edition of ‘Win7’ you want installed (ie. Starter • Home Basic • Home Premium • Pro • Ultimate)… if you don’t delete ‘ei.cfg’ file, that’s OK, just means Ultimate will install by default.
Vista
Place the downloaded ‘$oem$’ folder in the ‘sources’ folder of your ‘clean’ iso, and delete the ‘PID.txt’ file (if exists) from the same ‘sources’ folder and edit|save iso… during install you will have option to select the edition of ‘Vista’ you want installed (ie. Starter • Home Basic • Home Premium • Business • Ultimate)… if you don’t delete ‘PID.txt’ file, that’s OK, just means serial used on that file will determine edition installed.
• Please read the ‘readme’ files included in the download folder, for additional information.
• “UltraISO” recommended to edit|save your .iso, preserving ‘bootable’ image.
Editions for OEM Activation:
• Win10.. • Technical Preview • Consumer Preview
• Win7…. • Starter • Home Basic • Home Premium • Pro • Ultimate
• Vista…. • Starter • Home Basic • Home Premium • Business • Ultimate
• (Vista-Win10) If not known edition, branding only takes place.
How To: (Win 10)
– Place the downloaded ‘$oem$’ folder in the ‘sources’ folder of your ‘clean’ iso, and edit|save iso. OOBE.cmd (Install.cmd) will extract embedded ‘OEM--censor-’ serial from bios (if exists), and apply the serial during installation.
How To: (Win8.1)
– Place the downloaded ‘$oem$’ folder in the ‘sources’ folder of your ‘clean’ iso, and add custom ‘ei.cfg’ file to the same ‘sources’ folder and edit|save iso. Windows will install the edition identified from ‘ei.cfg’ file. (Project ‘Options’ folder includes ‘ei.cfg’ instructions). OOBE.cmd (Install.cmd) will extract embedded ‘OEM--censor-’ serial from bios (if exists), and apply the serial during installation.
How To: (Win8.0)
– Place the downloaded ‘$oem$’ folder in the ‘sources’ folder of your ‘clean’ iso, and edit|save iso. Windows will install the edition that matches the embedded ‘OEM--censor-’ serial in your bios (if exists).
How To: (Win7)
– Place the downloaded ‘$oem$’ folder in the ‘sources’ folder of your ‘clean’ iso, and delete the ‘ei.cfg’ file from the same ‘sources’ folder and edit|save iso… during install you will have option to select the edition of ‘Win7’ you want installed (ie. Starter • Home Basic • Home Premium • Pro • Ultimate)… if you don’t delete ‘ei.cfg’ file, that’s OK, just means Ultimate will install by default.
How To: (Vista)
– Place the downloaded ‘$oem$’ folder in the ‘sources’ folder of your ‘clean’ iso, and delete the ‘PID.txt’ file (if exists) from the same ‘sources’ folder and edit|save iso… during install you will have option to select the edition of ‘Vista’ you want installed (ie. Starter • Home Basic • Home Premium • Business • Ultimate)… if you don’t delete ‘PID.txt’ file, that’s OK, just means serial used on that file will determine edition installed.
• UltraISO recommended to edit|save your .iso, preserving ‘bootable’ image
Included link for images to be used with System Brand Changer if users prefer using a desktop branding tool with a nice gui, created by Alphawaves.
Dưới đây là liên kết để tải cái này đó ạ.
p/s:
Cảm ơn Mod nào đã duyệt bài này
How To:
Win8.x|Win10
Win7
Vista
How To: (Win 10)
How To: (Win8.1)
How To: (Win8.0)
How To: (Win7)
How To: (Vista)
p/s:
